ORIGINAL: xtraflyr
ORIGINAL: Ken-h
Hi Guys,
Here are some pictures of one of the Extra's with the Canister installed. This is a 25mm Drop flex header, and an MTW75 front exit canister. 1.3” had to be cut off on the header. You may need to sand off the lower left corner of the engine box side for header clearance.
Ken
HEy Ken,
How is the Canister attached in the fuse? Do you just have a tywrap with silicon tubing around it?
Frank
Hi Frank,
It was done like the picture I posted only for a single can. Just made a former from light plywood and cushioned it with tubing.
Ken
