RCU Forums - View Single Post - control throws
Old 11-12-2006 | 05:55 PM
mkystybx
Default RE: control throws
go to the airplane tab and instead of select airplane, click on the edit (current aircraft)option. Each control surface is link to it's wing. For example, if you want to change the maximium throw for the rudder, go to the vertical wing section and change the degree of deflection. The adjustments on your digital radio will work as well.
