RCU Forums - View Single Post - engine problems 2
Old 11-12-2006 | 10:39 PM
bruce88123
Default RE: engine problems 2
There is more of a tendency for an engine to start backward when hand starting than when using an electric starter. An engine that is running in reverse should not be run to full power and will usually refuse to do so and may actually damage itself doing so. There is usually no damage if an engine starts and runs in reverse briefly at slow speeds. Sometimes an engine will reverse after the start if it backfires for some reason.
