ORIGINAL: yarom
What did you end up using?
I see headers at zero drop and at 25mm - nothing in between.
ORIGINAL: HNPower
Strange, I have a 25mm drop flex header and the MTW75 canister and I couldn't get the header to fit. It seems that the 25mm drop is too much. I measured the drop required for the MTW canister is about 10mm. I must be doing something wrong.
I believe Ken said it earlier.. He used in the pictures a 25mm drop flex header and the MTW 75 front exit Canister.. If thats what is pictured then it will work..
Later,
Frank
