Yann, that is incredible. Good job
I am back working on mine after a long lay off. I haven't flown any type of model for over 2 months due to work.
I see some of you have used the Eurokit noseleg with Spring Air retracts. Did you make the retract pin yourself? I haven't got a lathe so can't do the necessary machining to make each end a different diameter. Is there anywhere that sells suitable pins?
