RE: Extra 300 Prototype #2
Using Epoxy the Stab weight before and after bagging was 5 ounces. So each stab gained less than an ounce of epoxy. I will have to repeat the test at a later date with a more accurate scale.
Albert... I hope you take accurate weights of you wings before and after bagging with poly u. I will do the same with epoxy.
