RCU Forums - View Single Post - Kelly's Brio build and pictures
Old 11-14-2006 | 04:27 PM
kregan's Avatar
kregan
Default RE: Kelly's Brio build and pictures
I finished the DEPS and completed the pull pull cable exits
at the same time. Once the tubes had been located I tack
glued them in place with thick CA.
I then made 2 light ply and balsa fillers to fill in the tail servo
holes and glued them in place with epoxy from the inside.
I used epoxy mixed with milled fiberglass to coat the inside
of the tube exits. I gained access through the rudder post
I had removed earlier in the build.
Once everything was dry I sanded down the tube exits flush
with the fuse sides.
ID:	560251   Click image for larger version
ID:	560252   Click image for larger version
ID:	560253   Click image for larger version
ID:	560254   Click image for larger version
ID:	560255   Click image for larger version
ID:	560256   Click image for larger version
