RCU Forums - View Single Post - Glowplug in, too much compression!!!!
Old 01-22-2003 | 05:17 AM
Flyfalcons's Avatar
Flyfalcons
Default Glowplug in, too much compression!!!!
Charge the starter battery?
Also check to see if it is flooded. Just before trying to start, remove the glow plug and hit it with the starter to blow out any fuel. Then replace the glow plug and try again.
What size is the engine? If it is a smaller engine it may not like a long glow plug. If it is 40 size or similar then it should be fine.
