RCU Forums - View Single Post - cyclon jak 09
Old 11-15-2006 | 04:33 PM
u07856's Avatar
u07856
Default RE: cyclon jak 09
I order my engines directly from Cyclon engines.
You can also order the engine in Germany
The quality of the engines is of a high level
All engines runs very well, very easy starting.
need some modifications for better performance.
I use this engine for Mini Team Race and 09 Diesel combat.
with aditional head shim + venturi of 2.8 mm it runs much better than the default 2.5mm venturi
prop 6x5 or F2D
In the Netherlands we have a rule in MTR that limits the prop size, minimal 7" props and normal available in the modelshop must be used.
For the JAK a 7x3 or 7x4 can be used, the standard graupner props are doing a good job.
It runs more happy with the 6" props
regards,
Marco
