RE: ?Glitch with Hitec 6 ch FM Dual Conv Reciever: why
Thanks for the info.
I found the problem. I am running the Futaba GY401 Gyro which has a Sensitivity Switching Connector. I remembered that the problem didn't exist prior to hooking the SSC up, so I unplugged it from the TX and no more glitch. I will check to make sure I had it plugged into the right channel and make sure it is adjusted properly.
Anyone else having a problem with these units please give me a heads up,,,much appreciated.
