RCU Forums - View Single Post - Jamara 330L
Thread: Jamara 330L
Old 11-16-2006 | 08:38 AM
BaldEagel's Avatar
BaldEagel
Default RE: Jamara 330L
Pics below show the intended motor box with the back support too the right, this is supposed to be bolted through the bulkhead into blind nusts and the box on the left is too be screwed and glued to that.
Second pic shows the MVVS 45 mag with the isolation spreaders installed showing more than adequate space required for instalation, I will have to make a new larger motor box to accomadate the isolation mount.
Pic three shows the miss aligniment of the elevator hinges, so contrary to my previous thoughts having the holes pre drilled will not speed up the process, the elevators are the same colour on both sides but even swapping sides made no difference, I will check the wings next.
Mike
EDIT: One thing I have not said is that in Europe this model only costs £239.00 that converts using 1.8$ too the £ at $430.2 now that is good value no matter what fittings are supplied, the combined horns and hinges supplied I have decided to use as they are under 25% of the weight of the Dubro replacements I would have used, I can always change them if needed in the future. I am trying to keep the weight down as much as possible.
ID:	561273   Click image for larger version
ID:	561274   Click image for larger version
