RE: Edge540 26cc
Hi
I' have the EDGE 540 with a SPE 26cc. Tested two different engines from peakmodel and both having the same problem. After approx. 2 running hours it seems that the supplied ignition fails and engine refuses to run at all. It will fire and run for a couple of sec but stops again. Tested with all different needle settings and different fuels, different carbs, battery packs, plugs etc. Nothing mechanical wrong with the engines. Suspecting the ignition module to be broken. Is there anyone else that has experienced the same problem?? Don't think this is just a coincidence since I have received TWO different engines from Peakmodel and both are having almost the same problem...
