Sealed Lead Acid Battery
I plan to use a 6 VDC 1300 Mah sealed acid battery as a pack for receiver on a scale big airplane with a total of 14 servos ( four 1/4 scale servos, five heavy duty servos and five standard servos) the airplane will be powered by two Zenoah G-38 engines, it is an American Eagle DC3 1/8th scale which presently weights 32 lbs assembled. I will use the mentioned initially sealed lead acid battery as a flight pack for receiver and would like to know will it work and be safe ? I have the CVC charger for that battery. Thanks.
Javier Ochoa
