RE: What Fuel To Use?
There really is minimal difference between the two, but being that you are a beginner, I would definitely suggest Omega (the pink stuff). That is what I use. The castor oil in this mix makes your engine more resilient to tuning mistakes, like an over-lean run. If you're very careful, and know exactly what you are doing, Cool Power should be fine.
-Mike
