RCU Forums - View Single Post - Tailpipe in can!
Old 11-16-2006 | 07:53 PM
AMA234's Avatar
AMA234
Default RE: Tailpipe in can!
ORIGINAL: FLYTICOUN
Hello guys
Do not thing i am crazy guys [:'(] Just give me respect i speak 3 languages and you?
This really work the can start to mealt at 1000 degrees celsius!
Your tailpipe from the turbine do not pass the 700 degrees celsius and the air coming out is around 400 degrees celcius that for the inner pipe the outside pipe is even cold.Most turbine shut it self if it pass the 730 degrees celsius
The can is most made from stainless for the outside and inside and the seal all both end are made of steal.
If you thing is dangerous do not use this ideal
See you tonext time![8D]
I don't think the number of languages anyone speaks makes any difference here... I however do speak two though so you may be smarter than me. [&:] I just think that people think it's kind of hair-brained, which is fine because it's not 'conventional'. But who cares? If it works, sweet! I give you credit though, I never would have thought of it. Let's see some pics of the dual-wall pipe! [sm=thumbup.gif]
