RE: Top Flite Cessna 310 posted
Sure .
I have two Rockwell Commanders, 79 inches, not built but in the box. The recommended wieght is 10 to 11lbs. They have fiberglass fuselages and nacelles and retracts.
I did one twin, a King Air, only 68" wing with two 40 fp bushing engines, one hp each. It weighed under 10 lbs. I'm not sure exactly what it weighed, but I believe it was under 10 #. It flew pretty good. But there wasn't much reserve power. The bushing engines are only 1hp. The 46 ball bearing engines are 1 1/2 hp. So, I think that two 46's can haul around about 15 lbs and probably no more.
I actually built an 80 inch C130 Hurk at 7 1/2 lbs. But it was for electric and wasn't built for any vibration.
I routinely build scale 60 size planes at 7 1/2 pounds. They are fat and with some detail.
I will concede that a mass produced plane may not be as light as ones built at home. I can see the C310 wieghing 13 or 14 lbs. I'll give you that much. But it just won't be very forgiving above that wieght. If I built a C310 myself and it wieghed 17 to 20 lbs, I would consider that a failure.
Now a ball bearing 60 can offers nearly 2 hp. But the C310 stats don't recommend a 60, they say a 50. The 50 is actually made in a 46 case and offers pretty good numbers. I'm actually using one on a Sig Bonanza, (7.5 lbs) Two 50's might be capable of flying a 17lb model. But again, I don't think there will be much reserve. The wieght of this model really suggest two 60's or even larger engines. I personally favor twin 46's because they idle so well and hold their tune almost permenantly. That is why I am so disappointed.
I feel it is very realistic to expect an 80 C310 to weigh 13 lbs and even less without the retracts. Especially if it is to have a good reputation and be forgiving and easily handled by the typical modeler.
I suppose time well tell if these numbers posted on the tower site are correct. And time will tell if this 310 flys well or not. I will hang back and watch before I run out and buy one. Or even worse, I might drag out one of the Commanders and get to work.
