IF you go with the P-51 then most likely it will end in disaster within 3 or 4 attempts at flight, this plane is very fast even stock and has a very bad stall habbit in turns and even at launch for begginers, if you slow it down and if it is below 100 ft you most likely won't be able to save it, look at the P-47 by E-Flight it is the best warbird RTF for control, it's stall rate is very low compared to all the others and cost is pretty much the same as the PZ P-51. almost everyone I know that have one say it's great, the folk wolf is nice but still has a higher stall speed than the P-47. I would suggest a nice trainer instead but if your gonna go warbird you should go with one that will give you half a chance of success, Good luck, I hope you do better than I did with my first warbird P-51,,,,(RIP) [&o]
