RE: Let's see your work shop!
as Pete says, just be careful with the foam insulation... if you're sesitive you might get a reaction to the "bad" air inside from the foam chemicals being released in the air.
there's some new researh against using foam for insulating, i know your're gona use epoxy & CA in there.... but in any case i would go the other route.
cheers, V.
