RE: Flaps and tip stall
When you say flaps add lift do you mean you will gain altitude at the same power setting? Am I confusing lift with altitude gain? I thought flaps were used to steepen the glide path while keeping the plane at a proper speed and attitude. They are also used to steepen and shorten the takeoff run, but I would think this requires more power because of the drag.
