RE: TF P-40 Build Thread
Josh, make a small incision with a #11 blade and then wick in thin CA, it will flow right to the area that needs to be glued, keep pressure down on the spot whilest doing this. The wing can be moved about so that the CA is made to run where it needs to go by gravity if you understand my meaning?
A drop of CA on the incision will seal it and it can be hidden with lightweight filler after.
Very easy to fix so don't stress it.
cheers
Peter
