ORIGINAL: fliprob17
I don't see why that would be a problem. The first is a NiCd and the other two are NiMh's, I have used both in my R/C Truck without any problems. The only thing I don't see is the C rating of the cells, to make sure they can handle a 30amp continuous draw. Otherwise you should be good with either.
okay cool, I think either would be fine as well. 30 amps really isn't that much so the batteries should be able to handle it without a problem.
