RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 11-17-2006 | 07:35 PM
  #3759
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
ORIGINAL: googledperson
Could you post some instructions on how to build that? or is it just different length foam glued together at angles. Also, how much weight does the foam safe CA add?
The glider is as far as I've gotten so far. A larger version will take some patching
together unless you have some larger sheet foam.
The one I made has a 7" winspan and was made from several plates of 1.75mm
foam.
Cut each wing half from one plate and then glue it to a balsa stick. I used hot glue
and the extra weight made little difference.
Then cut out the half circle bridge and glue it to the wings. Make sure you cut the wing
& bridge flaps for trimming. It does need a fine tune up.
Last add weight to the nose until you get a nice glide. You might need a bit of "up"
elevator to the wing tip flaps to get a nice lift.
