ORIGINAL: mc3854
That is the way I did mine. Rudder is one channel! Nose wheel on another! I have rudder as master nose as slave! I put the nose wheel trim on a dial so I can adjust as needed! Dial does not affect the rudder trim! Rudder trim will affect both but once rudder is trimmed simply re-adjust nose with the dial. Futaba 14 mz transmitter! Works perfect for me! I love this receiver!!
What I dont like about this setup is if you bump the dial, your nose is now out of trim. If you use the Rudder channel for the NG and slave the rudder (trim option off) you can then use the trim lever to adjust NG tracking and rudder stays in trim.
Just my .02
Todd
