ORIGINAL: ArmedZagi
Although I'm sure this has been asked before ...I just dont feel like slogging through 150+ pages for the answer
. What should I do if my one of the motors on my AA turns less RPMs than the other? I mean not just a little..but enough to make the plane turn 10 foot doughnuts without steering input. It stops spinning almost imediatly after I let go of the throttle. Its the left mottor that has the problem. And it WILL turn right, however the turns radius is about 30 feet.
Collin
I had one that I had to turn the trim knob all the way to one side right out of the box. Just for the heck of it, you could also try balancing the prop. If it vibrates alot, add a small strip of tape to one blade. If it vibrates more, try the other blade. Then try different size pieces of tape until it is smoother. The motor may be bad but I wanted to at least suggest that.
Chris
