RE: Splicing spars?
For sailboat masts, (They call them "spars", also) where the Sitka spruce pieces are not longe enough to make the length needed, a 12% splice works well. The splice should be inline with the forces which will be applied (on wing spars this would be verticle). Bundling the two pieces together and sawing both at the same time works. You can also sand them when together to get a perfect fit.
