RCU Forums - View Single Post - Foam friendly CA or Epoxy/slow stick
Old 11-18-2006 | 10:44 AM
spunkler
Default Foam friendly CA or Epoxy/slow stick
Hello all I'm a newbie with a few ?'s. For the slow stick I've read that many people use epoxy, along w/ tape, to glue the center of the wing and also the tail pcs to the fuse. Can you use foam friendly CA w/ accelerator instead of epoxy? Also when taping the elevator and rudder does a person need to pre bend the assembly before taping so as to have enough throw in each direction or tape it with it laying flat. Also you put tape on both sides correct? One more question. I have the e-flite outrunner 370 brushless w/ a 20 amp brushless sc w/ a 1320 ,11.1 thunder power 3 cell lipo. Right now I've got a APC 9x4.5 prop . Is this the prop I should use for the Slow Stick? Thanks
