RE: Switch Questions
Hi again Robert,
Thanks for the quick reply again. One thing you mentioned; if I decide to go with the failsafe route you said I could get away with one switch for both batteries instead of two? Now I would be interested in that. Would you mind expanding a bit on how to do that?
Also another question comes to mind: Is charging a big deal, or do you just plug in the Li-Po charger into the switch receptacle?
And on a similar note, in order to check voltage levels with a meter, is it just a question of again plugging into the switch to do that?
Thanks!!
Best,
Dave Killmer
