RCU Forums - View Single Post - Turbine Enforcer with Canards
Old 11-19-2006 | 10:41 AM
Wideopen
Default RE: Turbine Enforcer with Canards
4 flights, each flight is only 6 mins. do to the turbine size/fuel tank a 12 to 16lb thrust turbine will give a longer flight. I was using 25lb of thrust way to much. I never checked the batt after 4th flight maybe I could have flown longer!
