RCU Forums - View Single Post - Take off trouble
Old 11-19-2006 | 12:09 PM
Flying freak
Default RE: Take off trouble
Tail dragger take off is fairly simple apply light down up elavtor slowly advace trotal and give a little rudder to correct engine torque once speed starts to build realase up elvator (up was to give the back wheel traction but now that you have speed the rudder works) give a little down elvator to keep it on the ground till you know you have more then enough speed and gentailly pull back dont try to yank back as hard as you can or you will stall the plane and well you know what happenes next.
