RCU Forums - View Single Post - Chinese Nitro - Good or Bad Experience?
Old 11-19-2006 | 07:45 PM
MassiveMods's Avatar
MassiveMods
Default RE: Chinese Nitro - Good or Bad Experience?
Once nitro is exposed to Ultraviolet light and heat for extended periods of time it can become sensitive. Once it is diluted into a 2 stroke mix its pretty safe. Nitro by nature will explode under pressure regardless of wether its become sensitive or not. if you get some nitro on the floor and hit it with a hammer it will explode, if you do it once its mixed it is less likely to explode as readily..BUT ! i strongly advise not to do this under any circumstances, it may result in injury .
Anyway wether the Nitro has an indicatior or not in it its a hazard to transport in its natural state.
