I read in another thread a clever way to do this. Cut a 1/2 in wide strip of balsa skin for the channel but angle the cut so that you remove a V shaped piece ( balsa skin + some foam) Now route or hot wire the bottom of the V groove for the cable. The V shaped piece that was cut can now be glued perfectly back due to the V shape !
We try to fly between the rains
Tks
