RE: Edge540 26cc
To Yalaair :
If you get the spark at the right time at low rpm, as you said, then you should get some detonations when flipping the prop. Do you get no ignition at all ?. In such a case I suggest :
Low the oil content to 1:45 and use a good synthetic oil.
Make sure the gasoline flows and exit the muffler.
Try 98 octanes gasoline.
