RE: Problem with MVVS 58
... until it runs properly with (more or less) the "per book" settings, if I understood correctly.
Well, I'll try cleaning it again with that product and, of course, I'll look your link.
Only one comment: The engine is only 10 mm far from the firewall, so the carb passes throught the firewall and cames inside the fusselage.
Thank you, Pe.
I'll tell you
