RCU Forums - View Single Post - Swick Taylorcraft
Old 11-20-2006 | 06:38 AM
hifly2104
My Feedback: (7)
Default RE: Swick Taylorcraft
Ok That was supposed to work .The first picture is an incomplete fuse, which may seem easy but I have always found it easier to cut pieces together when there are more than one the same. As you can see where wing fastens isn't there on the one side and you can see the new wing .
Maybe its a location thing ,you being on the prairies lol ,but I think this is quite a large plane As you can see with the wing on it spans nearly 8' the fuse is over 14" wide. I will definitely be using a 148 engine or bigger on this plane
ID:	563590   Click image for larger version
ID:	563591   Click image for larger version
ID:	563592   Click image for larger version
ID:	563593   Click image for larger version
