ORIGINAL: buzzard bait
I think you were right to use some dihedral--it's not the same as a SPAD because there is a substantial fuselage above the wing--that creates the opposite of a dihedral effect. The plane would probably have been a little unstable right side up and stable upside down. Some dihedral will help neutralize the effect. Jim
Ok noted, thanks for the tip.
