RCU Forums - View Single Post - Questions re channels for servo wire in foam wing
Old 11-20-2006 | 09:40 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Questions re channels for servo wire in foam wing
I also use the hot wire method. But I don't do anything fancy, I just heat the wire (5/32 or 3/16" Music wire) and run it down by hand. You will need to re-heat the wire several times, and it really doesn't matter if you get sloppy. It's all under the sheeting, and you're really not taking away any strength.
