RCU Forums - View Single Post - Mixture adjustment
Old 11-20-2006 | 05:51 PM
tim220225's Avatar
tim220225
Default RE: Mixture adjustment
Do a search here on tuning a gas carb. We have discussed this in great detail. Once you have it adjusted do a plug check. The plug should be a light tan if it is adjusted well. I have a 44cc Echo conversion I did and it swings a Menz 20X8 at about 7100 or so. I would think you would find your engine will pull harder with a little larger prop.
