RCU Forums - View Single Post - possibly getting a used NEmesis
Old 11-20-2006 | 08:44 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: possibly getting a used NEmesis
the clutchbell holds up pretty well but if you do not take the time to be sure that the pinion gear to spur mesh and alignment is perfect you will have pinions for lunch. Take the time to go thru the truck front to back, inside and out, just make sure everything is up par.
Good luck with your new/used truck
above all have fun!!!!
