RE: Edge540 26cc
One spray of starting fluid will get that mother to pop. A continuous spay should keep it running once it starts to pop. If it does then its a fuel issue and back to the carb. If no poping with the starting fluid its back to the compression test. You may want to use a sulivan starter motor to get the ign. cranking too if you have a spinner. Just what works for me.
