RE: Whip Antenna
Be aware that there are two different kinds of "whips": base loaded (shorties), and full length. The full length variety keep your antenna the exact original intended length and are best for reception. Base loaded antennas are not what the radio manufacturer intended to be used and will normally reduce your range. But some guys (Gordon Dickens is one) have reported increased range using a base loaded due to the fact that the shorty antenna gets his antenna further from the noisy electronics (ECU, fuel pump, etc.) than the stock string antenna does. But a full length whip is the best choice for radio reception (keeps the original length and gets away from the noise), but is not always practical.
