RCU Forums - View Single Post - Crow on a Super Balsa Bandit??
Thread
11-21-2006 | 10:59 AM
7
Big Tony
Oct 2002
475
Redditch, , UNITED KINGDOM
RE: Crow on a Super Balsa Bandit??
I have a classic bandit and a super balsa bandit on the building board. The classic is an absolute darling to fly and land (hence buying the super bandit) with no hint of tip stall and it is a bit on the heavy side. I do a circuit on 1/3 power letting is slow down wack in take off flap again letting it settle then before the final turn into wind put full flap in keeping 1/3power on line it up LONG AND LOW approach as soon as you know its going to make the strip come off the power then if she looks to fast wack the airbrake in hold her off until she settles in - if you touch down before you ALMOST run out of elevator your going too fast.
And as for the adjustments for clam or stronger winds just keep the power on longer or come off earlier. Its the easiest plane to land I've ever flown its a darling.
Check the lateral balance
Thats how I land and I hope this help
All the best
Ant
Reply
Like
Big Tony
View Public Profile
Send a private message to Big Tony
Visit Big Tony's homepage!
Find More Posts by Big Tony
View iTrader Profile
