RE: Combat Models F-16
I thought Id provide a photo here incase some of you missed it - blown up detail of Jerry's jett-stream muffler install. Very slick, very well done - fits quite nicely.
I think Jerry noted earlier that he ran the fuel system configured with a header tank located right at the firewall. It is really amazing how well that configuration works for either a pusher setup like this, and also for tractor setups. Useful for those wanting to run a larger tank in a tight space ... you can place the main tank back closer to the wing if needed, and feed the header tank.
Also of note, the 60LX was actually first developed at the request of a modeler who needed as much power as possible to get an over-weight CBM F-16 off a limited runway. Worked quite well for that task - and has become a main-stream product now.
Bob
