What material to use for non metalic pull-pull setup?
Can anyone suggest what material to use for non-metalic cables in a pull-pull system? I can't run my antenna inside the fuselage if I use metalic cable, as the antenna would end up only about 4" away from the pull-pull cables.
Are there any real disadvantages to using non-metalic cables?
Do non metalic cable setups require differnet hardware (i.e rigging couplers etc. than a metalic setup?
Mark D.
