non matalic material for pull-pull
Ok., it seems Spiderwire is a good choice. Now how do you connect it to the rudder servo? Straight to the arm, or do you use some type of tiller (idler arm). This will be on a 1000 Sq. in plane and the calculated maximum load will be about 60 oz of torque. Also, do you use some type of coupler on the servo end, or just loop the thread through the servo arm directly?
MarkD
