Not to beat the subject to death, but making sure the servo linkage is attached in the appropriate place is pretty important. The only thing I didn't see brought up was mechanical advantage. Setting the throws accurately at the servo is important. Not that making small changes at the radio is bad, but you don't want to make extreme changes there. You would be giving the control surface too much leverage and causing servo gear failures or servo stalling. Just a thought.
