RE: Extra 300 Prototype #2
I have always used epoxy and a vacuum bag when sheeting my wings, etc, and felt it was lighter than any other method. Well I am throwing down the gauntlet.
I bagged the wing on the 300 using epoxy. The weight of the wing ready for bagging plus the top and bottom sheeting was 1 lb. 13.3 oz.
After bagging with epoxy my wing weight is 1 lb 14.3 oz.
So that means one ounce was added using epoxy to laminate my wing skins (top and bottom!) on to a 40% extra 300. Can anyone put up their numbers for sheeting a 40% wing using a different method?
By the way... What do you guys think of using laminating epoxy to install the leading and trailing edges of all the surfaces?
Rob
