RCU Forums - View Single Post - engine trouble ?
Old 11-21-2006 | 06:56 PM
drone pilot
Default RE: engine trouble ?
All good suggestions. I would first, after checking for a tight fuel system (no air leaks) set carb barrel to the just closed position. Close main needle and then close idle needle until it just stops. DONOT use any force. Turn idle needle out 1 1/2 turns. Turn main needle out 1 3/4 to 2 turns. With no glow on open throttle just a little and put a finger over exhaust and crank engine. You should get fuel up to carb by doing this. If you get fuel to carb, try staring engine ( glow power on). If you donot get fuel I would think you have an obstruction in the main needle body. If so clean needle body and try again. Good luck. I have three TT Pro .61s and all run great.
