RCU Forums - View Single Post - Spinner Balancing
Old 11-21-2006 | 07:18 PM
Uncas
Default RE: Spinner Balancing
Aerobob,
I agree with you, but only because we are dealing with a cone. If this were a cylinder or a shaft then you would have 2 effects to worry about: The imbalance between front and rear which would induce a wobble around the center point, and the imbalance of too much weight on one side of the shaft, which would cause a wobble around the shaft.
