RCU Forums - View Single Post - 3M Mintor 140 and 170 2-stroke from Italy
Old 02-18-2003 | 06:47 PM
  #31
Luke 3D
Default 3M Mintor 140 and 170 2-stroke from Italy
hey guys I was surfing the internet and i found some engine rpm figures.
i was just comparing the MOKI 135 with the 3M Mintor 140 and i found some interesting results;
the 3M Mintor 140 with tuned pipe and 15 percent nitro fuel turns an APC 16*12
at 8350 rpm.It costs with pipe $518
The Moki 135 on straight fuel with a standard silencer turns an APC 16*12 at 8300 rpm.
It costs with silencer $300.
We can see from these results that the Moki is a lot more powerful because it is only 50 rpm slower when on straight fuel without a pipe , unlike the mintor)
As you can also see the Moki 135 is also a hell of a lot cheaper(by $218!). One guy in my club has a Moki 135 and it seems to throttle brilliantly( as good as a YS engine).
On looks alone the 3M Mintor wins but if you are concealing the engine inside a cowl then it doesn't count for much.
It is clear that the MOKI 135 is cheaper,and more powerful, therefore better!
you can by the Moki series of engines at
www.justengines.co.uk
Luke
