RCU Forums - View Single Post - Electronic Ignition Interference issues (worries)... Help!
Old 01-23-2003 | 12:10 PM
stomper
My Feedback: (20)
Default Hey Tomapowa
I currently plan to have both battery packs (ignition and radio gear) side by side towards the tail of the plane (for adjusting C.G.
BAD Idea
You went to keep all engine related equipment (batt.,switch, ignition module) separate from your radio gear! As well don't use a steel push rod or cable between your throttle servo and engine.
If you have any other questions fire away. Best of luck!
Doug
